It is currently Sat Aug 09, 2025 10:25 am
PostPosted: Fri Mar 11, 2011 9:48 am
I made a maple neck (never again...its hard!) for this one and im just coming back to it after some time away.
I was planning to bind in Maple and wanted to bind the FB. Will Maple binding on maple neck on Mahogany guitar look weird?
I cant quite decide if i should use a darker binding..
Any thoughts gratefully received
PostPosted: Fri Mar 11, 2011 10:29 am
Last Name: Kincheloe
Maple neck with maple fingerboard binding would be weird... but maybe cool. Like the fingerboard is inlaid into the neck. Although if the neck is straight grained and binding is curly with a rosewood side purfling or something, I think the separation would be enough to look more normal, if that's what you want.
I do think body binding matching the neck wood as closely as possible would look nice, more like the neck is part of the body rather than a separate piece tacked on. Maybe do non-matching fingerboard binding? Indian rosewood on a light Honduran rosewood fingerboard wood look awesome, I think. Looks like you've already got a nice Madagascar board slotted there, but you could save it for later if it's a scale length you do regularly.
Or maybe mahogany binding on the Madagascar board? Could be an interesting look.
Or Madagascar bindings matching the fingerboard, with a maple purfling strip between the binding and board.
PostPosted: Fri Mar 11, 2011 11:33 am
Thanks Dennis
some cool ideas.
I,m a bit limited in my choices living where I do between expensive shipments wow7-eyes
Tried koa didnt like it, plain maple neither.
Tried a simple bwb with some curly maple and it looks fine I think
with some dark dots
PostPosted: Fri Mar 11, 2011 2:15 pm
First name: Ellison
City: Whitman
State: MA
Filippo Morelli wrote:
Purfling is the answer.
Filippo
I'll second that motion.
PostPosted: Fri Mar 11, 2011 3:27 pm
Last Name: Forbes
City: Gilbert
State: Arizona
Zip/Postal Code: 85297
I use Maple binding on many of my Mahogany guitars, but as already stated the trick is to have a purfling strip between the plate and the Maple to give contrast. This is the most important on the top especially where two very similar colors of wood will be meeting, and there needs to be a purfling line there to define the joint. As far as on the neck I also believe that it might look cool, but contrast again would be needed. That can be accomplished with a different wood for the neck binding or creative use of purfling again.
http://www.sixgunguitars.com
PostPosted: Fri Mar 11, 2011 3:35 pm
First name: Heath
Last Name: Blair
City: Visalia
i think you nailed it. looks great. inspiring actually.
sweat the small stuff.
PostPosted: Sat Mar 12, 2011 12:15 am
Thanks alot you guys
First wood dust in a couple of months..
I got stoked and cut the binding channels on the back
Not perfect but I,ll get away with it fine !
